Online Now [445]:
Visitors: 445
Today: 25509
Total: 142408344
Forums › The Car › Solved 206 Problems › Car Juddering? Loss of Power? 1 way to fix
PostPosted: Mon Apr 26, 2010 8:45 am Up
Before this site went down i had a problem with my car juddering and eventually found out what was causing it so here is what i did to sort it out
If you have any of the problems below then give this a try
My car was doing a number of things:
Juddering as if the car was going to stall
Loss of power
Not starting up straight away
Loud shocking noise coming from underneath the bonnet
What to do
What i did was look under my bonnet and i could see a jolt of electricity jumping from my coil pack to my engine rocker cover. So i tried spraying wd40 on the coil pack which did get rid of the jolt of electricity for a while but the car still continued to judder.
I then decided to try and change the coil pack but after seeing prices from peugeot i decided against it and had a research on what to do.
Citreon saxo's and Peugeot 206's both share the same coil pack so i went down to my local scrapyard and picked up a coil pack for only £15! Tried it there and then and the jolt had gone and the car sounded right again
I took the car for a drive and to this day its been perfectly fine
Hope this helps any of you with the common juddering problem
Any comments welcome
PostPosted: Mon Apr 26, 2010 10:35 am Up
very good solving a 206 problem,i will keep that in mind if it happen to my car someday Smile
