Online Now [204]:
Visitors: 203
Today: 27669
Total: 143336641
Forums › The Car › Solved 206 Problems › Peugeot 206 GTI (130) Brake Servo / Booster
Seanie280672
PostPosted: Sat Aug 06, 2016 6:53 pm Up
Hi, just a quick question, my brake servo is leaking air and has been for a while, its coming up for MOT soon so I need to get it changed quite quickly, the part number for the servo is 4535 T6.
My car is a Peugeot 206 GTI 2003, ive managed to get the brake servo and master cylinder off a 2001 GTI, the numbers on the sticker on the servo dont match, except the size 5 but im not sure what these numbers are for (03-7864.4401.4) im quite confident at fitting it myself as I am quite good with mechanics, however, will this servo work OK as a replacement, looks the same, same size, same fittings, ABS etc ?
I'll remove the master (only 2 x 13mm bolts) and pull to one side so I dont need to bleed, then its just a case of removing the securing pin and 4 blots behind the glove box as well as the battery and battery box to get it out.
PostPosted: Sun Aug 07, 2016 7:12 am Up
Their servo should fit but they master cylinders will be different. They should be there same size but isn't there a connector on their 180 m/c?
Seanie280672
PostPosted: Sun Aug 07, 2016 8:39 am Up
Thanks for your reply
the masters look exactly the same too, same fittings, same pipes etc, if need be, I could always just fit the master that came with the part I brought.
ive just got the details off the servo I want to fit, the numbers are 03.7762.5301.4, googling this relates to a Peugeot 206 GTI 2001, and the one currently fitted is 03-7864.4401.4 which is a Peugeot 206 GTI 2003, its the 135 version not the 180.
I recently found out from my mechanic that pugeot are a bit of a nightmare for parts, the reason there are so many variants is they buy parts for their cars closest to them at the time, instead of getting the same part from other versions shipped to them.
Seanie280672
PostPosted: Fri Aug 12, 2016 5:25 pm Up
Just so you guys are aware, I changed the servo today for the one from the 2001 GTI, its working fine although its a different part number and the hissing has gone, took approx 1 hour and thats only because, the little O ring on the back of the master, fell off and I found it after putting everything back together so had to take the battery and battery box back off again and remove the master to stick the O ring on the back.
The hardest part in all honesty was removing the pin under the glove box with connects the back of the servo to the brake pedal arm.
