Latest: sparrowdclxvi
Overall: 17139
Online Now [528]:
Visitors: 527
Today: 124520
Total: 112936003
Forums › The Car › 206 Talk › Condensation fix.
Condensation fix.
danhodson
PostPosted: Tue Jul 20, 2010 4:13 pm Up
Just a little heads up for anyone suffering with condensation in any of their light fittings.
Rather then spend ages removing lights, remove the majority of the water with a hair dryer then pop a few packets of Silica Gel in the unit to soak up the rest of the moisture. It worked a treat for my Crystal headlights.
bolly92
PostPosted: Tue Jul 20, 2010 4:31 pm Up
how do you get it out?? Smile
Peugeot 206 1.9 LX - SOLD
_________________________________________
Peugeot 206 1.6 XSi 16v
TEAM: Colour Coded
TEAM: Yellow Calipers
- Phase 2 Rear Lights
- Phase 2 Bootstrip
- 206info Sticker
PostPosted: Tue Jul 20, 2010 4:36 pm Up
This will work for a while but what happens when
eventualy the silica-gel gets saturated and looses
it's moisture absorbing function?
danhodson
PostPosted: Tue Jul 20, 2010 4:39 pm Up
you don't place it in the reflector part of the light, pop it behind the where the bulb clips are.
danhodson
PostPosted: Tue Jul 20, 2010 4:40 pm Up
As long as the moisture has been soaked up and the seal is well... sealed, the moisture shouldn't return. But if it does, you heat the packets in the oven to 120 and they'll work all over again.
PostPosted: Tue Jul 20, 2010 4:44 pm Up
OK, that sounds good to me.
Rob2859
PostPosted: Tue Jul 20, 2010 6:24 pm Up
i just found leaving the cover off at the back worked fine
danhodson
PostPosted: Wed Jul 21, 2010 1:25 am Up
It didn't work for me, the moisture just came back as the temperature returned to that of outside the engine bay.
spike_202
PostPosted: Wed Jul 21, 2010 1:38 am Up
good tip! 1 of my angel eyes started misting up a while back so i just put my lights on to heat them up, i'll try this if it returns.
**spike's project**
TEAM:+200bhp
danhodson
PostPosted: Wed Jul 21, 2010 1:42 am Up
Turning the lights on worked for me but it often returned over night when the temperature dropped. Just been out to check if its returned and with the gel in there is no sign of moisture at all.
PostPosted: Wed Jul 21, 2010 1:58 am Up
just what I used to do with my fogs Laughing
benb
PostPosted: Fri Jan 21, 2011 5:35 pm Up
thanks for tip hope it works Smile
1.1lx 2000 plate
PostPosted: Fri Jan 21, 2011 5:36 pm Up
Ive got 8 industrial sized ones in my car atm to stop the windows fogging over night. Works a treat! They are like 20cm by 10cm Laughing
benb
PostPosted: Fri Jan 21, 2011 5:41 pm Up
i am going to get loads from work tomo Razz haha my car is guna be stacked with em top to bottom lol
1.1lx 2000 plate
