Posted: Wed Aug 04, 2010 2:12 pm |
cgi.ebay.co.uk/NEW-Bre...3f014455d3
What is the actual point in these things, I cant think of a proper purpose as I thought it was illegal to have the breather hose off because the oil gives off toxic gases which are then put through combustion to get rid of them???
Ben.M
| "Being second is to be the first of the ones who lose. " Ayrton Senna | |
Posted: Wed Aug 04, 2010 2:22 pm |
Ben.M wrote: |
Where did you hear that?!
| Quiksilver: 1.6 16v Engine Conversion. | |
Posted: Wed Aug 04, 2010 2:23 pm |
vintageoriginal wrote: |
Ben.M wrote: |
Where did you hear that?!  |
Dunno now, just something I remember
Ben.M
Posted: Wed Aug 04, 2010 2:26 pm |
I don't believe the oil breather is a tested item in the MOT. As to your original question, they're useful if you've fitted an induction kit which doesn't have a fitting to allow for recirculation.
Posted: Wed Aug 04, 2010 2:30 pm |
I don't believe the oil breather is a tested item in the MOT. As to your original question, they're useful if you've fitted an induction kit which doesn't have a fitting to allow for recirculation. |
Ah ok, thank you
Ben.M
Posted: Wed Aug 04, 2010 3:14 pm |
adding onto this, im thinking of getting one, because i keep breaking the breather pipe.
what dimensions would be best to get for the filter?
Posted: Wed Aug 04, 2010 6:22 pm |
is it likley to cause damage to the engine leaving it open?
Posted: Thu Aug 05, 2010 10:47 am |
Rob2859 wrote: |
is it likley to cause damage to the engine leaving it open? |
I dont think that much pressure build up in the breather pipe so with it being left open I doubt it would make much difference.
Abzynthe, the best thing would probably to look on your engine where it goes and using a tape or sumething see what would look/fit best
Ben.M
Posted: Fri Aug 06, 2010 8:47 am |
thanks ben
