Latest: tbafonso
Overall: 17130
Online Now [32]:
Visitors: 31
Today: 843
Total: 104125670
Forums › The Car › 206 Talk › Replace Cigarette Lighter
dhblewis
PostPosted: Sat Aug 07, 2010 11:01 am Up
My cigarette lighter broke, even after changing fuses so I have disconnected it and have bought this one from halfords.
How do I install it as there is a connector that just plugged into the one I disconnected see below.
Any help would be apprecaited as I need it to working by Monday to power my GPS.
01 206 LX 1.1
PostPosted: Sat Aug 07, 2010 11:30 am Up
Is the one from Halfords just two wires, a positive and a negative?
If so, just cut the connector off and wire it up to the +12volts and the earth
Ben.M
PostPosted: Sat Aug 07, 2010 12:42 pm Up
IIRC the blue wire is positive, there is also a green and a thin blue wire, I think the green in negative/ground and the thin blue must be the + for the light,
Ben.M
dhblewis
PostPosted: Sat Aug 07, 2010 12:53 pm Up
there's a green & yellow one which is the ground I think and then there's a thin grey/blue & a pink one too? Not sure which is which!
Also, could I hook up 2 cigarette lighters to the wires or would I need to change the fuse?
01 206 LX 1.1
PostPosted: Mon Aug 09, 2010 4:59 am Up
The pink one is the +12volts
You could wire two cigarette lighters into it, but it might blow the fuse if you run things off it that use a lot of power
