Latest: tbafonso
Overall: 17130
Online Now [55]:
Visitors: 54
Today: 35823
Total: 104505888
Forums › The Car › 206 Talk › Is a ecu plug and play ?
b47t0n
PostPosted: Fri Aug 13, 2010 11:44 am Up
If I got an ecu from a same engine but from
A different car Ie 306 2.0l hdi would it be plug and play on my car ?
Got Smoke ?
Team:Apprentice Budget
vintageoriginal
PostPosted: Fri Aug 13, 2010 12:00 pm Up
No, it is linked to BSI and key transponder.
Quiksilver: 1.6 16v Engine Conversion.
puglad
PostPosted: Fri Aug 13, 2010 12:59 pm Up
Deffo NOT!
+2 Positive Feedback
eBayer seller 206 GTI Spoilers, £120 Colour coded Inc Post!
ModifiedJunkies Performance Parts Centre
Proud owner of a french motor
PostPosted: Fri Aug 13, 2010 2:22 pm Up
Pre-multiplexed cars don't have a BSI.
b47t0n
PostPosted: Sat Aug 14, 2010 3:38 am Up
Ahh ok no worries
Just as I need a backup ecu incase the 1 I'm
Mapping ever messes up .
Got Smoke ?
GazRG
PostPosted: Sat Aug 14, 2010 4:13 pm Up
They do actually. It's more simple than a multiplexed BSi but still present. It's located near the fusebox.
'98 MGF 1.8i
Team: ex-206 owner
