Posted: Tue Aug 17, 2010 7:32 am |
You may have to share some info on where to buy parts there's a guy on cupra.net with it mounted behind there, with it just viable behind the slat below the badge grill on the R bumper, looks smart as hell
Posted: Tue Aug 17, 2010 7:45 am |
Aye, that's where the idea came from. It will hide the engraved Forge FMIC as well
On a 206 however, anywhere in the front grille will be adequate I'd imagine
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Tue Aug 17, 2010 7:48 am |
Ape wrote: |
On a 206 however, anywhere in the front grille will be adequate I'd imagine |
on a 206 i would be tempted to put it behind the upper grilles, would look cool i would think
Need to find a Twin pass intercooler for mine,
Posted: Tue Aug 17, 2010 8:04 am |
Lodey wrote: |
Ape wrote: |
Need to find a Twin pass intercooler for mine,  |
seat sport one?
Posted: Tue Aug 17, 2010 10:19 am |
Ape wrote: |
Anything you do to keep engine temperatures to a minimum is worth doing in my eyes. |
That's suggesting get rid of as much heat as possible. Overcooling the oil is very undesirable.
Lodey wrote: |
on a 206 i would be tempted to put it behind the upper grilles, would look cool i would think |
But you wouldn't be able to see it....
Posted: Tue Aug 17, 2010 10:44 am |
Edward wrote: |
Ape wrote: |
Thats why you use a sandwich plate with a thermostat in it (as mentioned) to prevent over cooling.
Posted: Tue Nov 22, 2011 6:49 am |
Has anybody fitted one to there 180 yet ?
Posted: Tue Nov 22, 2011 11:49 am |
You kind of have one on the 180 already.
Posted: Tue Nov 22, 2011 1:18 pm |
Im fitting one for the conversion for my 1.4, pretty p**s easy tbh
You just need to calculate the flow of oil from the pump (check the pump is within tolerences and pushing out what it should) and this should allow you to find which one will be suitable for your needs.
To large and the pump cant cope = starvation. To small = Oil burns/thins
| Team Impossible Possible
Posted: Tue Nov 22, 2011 2:29 pm |
Considered fitting one but it never gets near the red and i use 10w60 millers race oil so the high temp wont thin the oil that much anyway. I'd go for better oil rather than a cooler.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
