Latest: Stu-mill
Overall: 17131
Online Now [330]:
Visitors: 329
Today: 101835
Total: 104787379
Forums › The Car › 206 Talk › tyre stretch?
tyre stretch?
Go to page Previous  1, 2
Seb
PostPosted: Thu Aug 19, 2010 6:00 am Up
Staff - Seb
Uz wrote:
I understand why the majority of people don't like stretched tyres but why do BMW send the M3 CSL out of the factory with stretched semi-slick tyres on the back wheels..?
They're an engineering/automotive company who know exactly what they're doing! Plus semis will have much better toughness than a tread tyre.
M60SHW
PostPosted: Thu Aug 19, 2010 8:02 am Up
Also a dowt you insurance would be to happy with it. Just get some proper sized tyres for piece of mind if nothin else
Team, ST
Team, Gti 138 track slag
pete_206
PostPosted: Thu Aug 19, 2010 8:08 am Up
I had 195's stretched over 205 rims. the problem with running a stretched tyre everyday is that it can bald the inner edge of the tyres quite drastically. My old job used to involve practically driving for a living though. If I were you I'de just fit the right size tyres if you're driving your car alot.
With inner wall tyre wear it's also difficult to see how worn the tyre is, unless you take the wheel off to have a look.
Low & Slow 1.4 8V glx
my 206 project page Smile
Ruffy_206
PostPosted: Thu Aug 19, 2010 9:51 am Up
Custom - Gold Stars
strech is cool and i cant see how it works but thier is enough people out thier doing it.
Ross
PostPosted: Thu Aug 19, 2010 11:47 am Up
I've just PM'd you back Teebag but I'll reply in here aswell.
I'm running 185/45's on a 15x8 wheel and they've been perfectly fine, two of my dustcaps are seized on so I can't put air in two of the tyres, not that I've needed to, they don't leak air at all. I've given the car death on a few occasions, I've had the tyres screeching and felt the weight of the car shifting, so to my mind the tyres would just break traction before you even get near popping them off the rim. Another couple of ways that would back up this theory is that drift cars run stretch with no issues, and obviously they put massive stress on their tyres! Also, when I went to have my wheel alignment sorted out, I got speaking to a guy who worked at the place I went to, I think he said his son ran stretched tyres, and he explained to me the amount of pressure you'd need to physically pop the tyres off the rim, and it was a lot, you'd not get near that sort of pressure whilst cornering, that was the point he was making.
pete_206 - the tyres balding on the inner edge was most likely down to poor wheel alignment...
My stretch:
One downside I've found to stretched tyres is that I get a lot of stone chips to the rear wheel lips, as obviously they're more exposed! Doesn't bother me much though, the red lip tape stops most of it, and failing that I just touch them up with touch up paint, they were chipped when I bought them anyway.
TheUniqueOne
PostPosted: Thu Aug 19, 2010 11:55 am Up
my mate just put some 165/50 on his 7J wheels some SERIOUS strech on them but he uses it everyday with no prblem
cheers
paul
Ross
PostPosted: Thu Aug 19, 2010 12:06 pm Up
A guy on Club Lupo ran 165/50/15's on an 8J rim...
www.tyrestretch.com/zp...=&q=85
Extreme to say the least, I think he was a bit scared of them himself so never really pushed it hard round corners. They never came off though. And for the record he now runs wider tyres.
I don't condone anything that extreme, but the point is, he ran them successfully so it shows how far you can potentially go I guess.
PostPosted: Thu Aug 19, 2010 12:16 pm Up
Tyre stretching is as daft as tinting lights and modifying any other safety item.
Page 2 of 2
