Latest: Stu-mill
Overall: 17131
Online Now [257]:
Visitors: 256
Today: 19556
Total: 104655844
Forums › Tuning, Modification & Legal › Project Cars › 206 1.6 HDI
206 1.6 HDI
Go to page Previous  1, 2
twed207
PostPosted: Thu Feb 18, 2010 3:33 pm Up
guy, the EGR come into the inlet manifold at the top left of the engine bay...
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
Ruffy_206
PostPosted: Thu Feb 18, 2010 3:35 pm Up
Custom - Gold Stars
took mine out the other day and give it a clean. and managed to touch the white rag and nows its black woops.
twed207
PostPosted: Thu Feb 18, 2010 3:55 pm Up
how u take it off mate? just unscrew the screw/bolts where it fixes to the inlet manifold?
206 2.0HDi
My 207 WIP
L200 thread
Ruffy_206
PostPosted: Thu Feb 18, 2010 3:57 pm Up
Custom - Gold Stars
i took it off from the top where you have pictured i only done it as i drop a socket down thier and that was the only was to get it so why is was out gave it a clean and put it back on its just two torx and it pulls out qutie a tight fit.
FLaCk
PostPosted: Thu Feb 18, 2010 4:31 pm Up
well the EGR its located behind the Air Filter... so...its the other side... the picture that twed207 shows the end of EGR...
the EGR is this...
well the car work very well without FAP and EGR... the temperatures of removing FAP reduced drastically and gave the health of turbo
I do not have the outline of the suppressor of FAP... but its very easy to make...
only need to copy the FAP...a pipe of iron or steel 60 mm serves perfectly...you need to plug the sensors back in the pipe... but what really matters is the new software... without it is better to be quiet...
in some versions of software ... the PSA program has the option to turn off or on the FAP... this case my car has a new version of software peugeot... and have the option...but most 206 1.6hdi do not have..its comon to see em citroen c4...peugeot 407...
but did not want to take risks in simply turning off by the program ... then created a new map...
206 VC POWER
Ruffy_206
PostPosted: Thu Feb 18, 2010 4:39 pm Up
Custom - Gold Stars
so if we got a update on the software thier sould be an options where by you just turn it off?
or do you need it mapped out of the system?
FLaCk
PostPosted: Thu Feb 18, 2010 4:47 pm Up
its better to mapped out of the system...
well... you put some values of FAP...between...
to understand...this...you need to understand how the FAP system works...
have a sensor before and after in FAP ... that indicates the values that this moment in this running...
so...you have to give false values to ECU...To avoid problems and errors...is why it puts the sensors back in the new pipe... to avoid errors...
the new software of PSA not known if avoiding errors... so for sure...you need the mapped the ECU...
only a master in the remapped´s .... do this...
206 VC POWER
Ruffy_206
PostPosted: Thu Feb 18, 2010 4:56 pm Up
Custom - Gold Stars
thats is what i gatherd, i have done a bit of reading on fap. and am understanding how it works. i want to get this done end of this year can you not run a new turbo back pipe with the sensors tapped into it?
FLaCk
PostPosted: Thu Feb 18, 2010 5:10 pm Up
you can put another turbo in this pipe... or make a new one...to fit on turbo... dont have any problems...
so if you know how the FAP works..its easy to trick the system...
206 VC POWER
twed207
PostPosted: Thu Feb 18, 2010 7:44 pm Up
FLaCK,
with you waying the 'new version' of software... i presume you mean the software that comes with the second generation of the DV6TED4? as my car has slightly different parts than yours does...
anyway... i'm still getting it mapped out by a remapper. Smile
206 2.0HDi
My 207 WIP
L200 thread
FLaCk
PostPosted: Fri Feb 19, 2010 4:57 pm Up
my car have a differents parts than the others 206´s... more recent...
supply oil to the turbo... for example...
in the software of PSA recognized as a 308 lol...
206 VC POWER
Page 2 of 2
