Posted: Sat Aug 28, 2010 7:05 am |
Posted: Sat Aug 28, 2010 7:06 am |
says it not available
Posted: Sat Aug 28, 2010 7:19 am |
The upload may still be processing at the min sorry about that
Posted: Sat Aug 28, 2010 7:57 am |
still not availible :S
Posted: Sat Aug 28, 2010 8:06 am |
Wiliam_morgan wrote: |
still not availible :S |
yeh Youtube can sometimes take ages... Especially as its a Saturday so all those bloggy people are probably uploading their weekly rant session
Posted: Sat Aug 28, 2010 11:49 am |
Ok I've sorted the video out, it should work now, would apreciate a few views and feedback to whether the slight hovering is normal in that case, cheers
Posted: Sat Aug 28, 2010 11:53 am |
Mine does this too but only on a warm day
Posted: Sat Aug 28, 2010 11:57 am |
mine does this but not as much since i had it serviced
| 04 plate silver, gloss black nimrods, 180 brakes, more to come..... | |
Posted: Sat Aug 28, 2010 11:59 am |
mine jumps to about 1.6-2k revs, then settles just below 1k almost immediatly (how the hell do you spell that?)...
Posted: Sat Aug 28, 2010 12:02 pm |
Is the unsettled idle towards the end of the video anything to be concerned about? The car was serviced in september and checked over by the dealer before purchase in march
MOT is due in september and the car is getting a check over by the dealer, I'm just wondering if it's worth pointing it out to them
Posted: Sun Aug 29, 2010 11:04 am |
Looked under the bonnet today, made sure all the wire plugs on various sensors were in properly, shut the bonnet, and started up 5 mins later. Starter motor was very fast, but didn't start the car more than likely because I didn't hold it long enough
Pushed the key again and the starter motor still made a fast noise, but taken the normal time to start up. Throttle was much more sensitive than usual. Then on my journey home, the starter motor made two sounds and started the engine like normal, and the throttle sensitivity was back to normal.
