Online Now [414]:
Visitors: 413
Today: 102318
Total: 142612646
Forums › The Car › 206 Talk › does this work??
does this work??
Schnakey
PostPosted: Wed Sep 01, 2010 11:02 am Up
Need a new ECU, can I reprogram my keys like this to the new ecu???
CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP KEY)
1. Ensure all doors are unlocked using the key.
2. Press and HOLD the large plip key button while the LED flashes continuously for 20 seconds. After 20 seconds press the small deadlock button once while still holding the large button.
3. The LED will stop flashing.
4. Release the large button and the LED will light constantly.
5. Press the large button once and the LED will go out.
6. Open the door and hold the Plip key near the Ignition switch and press the large plip button once.
7. Turn the ignition ON, wait 10 seconds and then turn the ignition OFF.
8. After 5 seconds the Plip should now operate.
