Latest: tbafonso
Overall: 17130
Online Now [313]:
Visitors: 312
Today: 51840
Total: 103413120
Go to page Previous  1, 2, 3 ... 15, 16, 17 ... 31, 32, 33  Next
imjeeves
PostPosted: Sun Feb 13, 2011 11:37 am Up
What ride height do you run at the back? There is something wrong if they are that far into the arches
macj
PostPosted: Sun Feb 13, 2011 11:40 am Up
Standard ride height.... I would raise one spline for gravel/forest
EdCherry
PostPosted: Sun Feb 13, 2011 1:13 pm Up
Exit of the pit lane though yep?
The rears arn't locked so assume it was in the process of pulling it (although highly doubt the photographer was that lucky!), which will make the back squat anyway, with a bit of throttle it will lift the front end too. Id say that there is nothing wrong other than the fact its probably a bit soft.
Whats your setup?
macj
PostPosted: Sun Feb 13, 2011 2:08 pm Up
Standard torsion bar settings height wise, Standard 138 ARB and Gaz custom uprated shocks.. set approx 55%
EdCherry
PostPosted: Sun Feb 13, 2011 4:12 pm Up
Standard bars too?
st3v3n
PostPosted: Mon Feb 14, 2011 6:08 am Up
Looks normal to me Mac. Here's a pic of mine from the front end on a hairpin.You can see the inside rear lifting which means the outside rear has the full weight on it so will be compressing the wheel up into the arch. With the lighter rear end in a rally car, you can't always assume thicker ARBs will fix things as they will just cause the inside to lift more. I'd be experimenting with different torsion bars too. If you can get a few different ones then a decent mechanic with you who can swap them quick enough, you'll see what results you get on the test day.
ICE goes in drinks. NOT in cars.
macj
PostPosted: Mon Feb 14, 2011 11:28 am Up
My inside rear does not lift at all...... not even on really tight bends
macj
PostPosted: Tue Feb 15, 2011 11:18 am Up
OK guys, I have booked the test facility for saturday 26th March.
Address is Runway 2
Bradwell Airfield
Bradwell-on-Sea
Essex CM0 7QF
A fellow competitor has expressed an interest in some testing in his 106 Rallye so should be a good day.
imjeeves
PostPosted: Tue Feb 15, 2011 2:04 pm Up
will try to make it along to this. its in my diary
macj
PostPosted: Tue Feb 15, 2011 4:22 pm Up
Given the distance, Do you need a bed for the night?
imjeeves
PostPosted: Tue Feb 15, 2011 4:46 pm Up
Bit early for that we havent even met yet! Wink
Erm will need to see where i will be working that week but it would be best if i stay somewhere closer i guess.
imjeeves
PostPosted: Wed Feb 16, 2011 2:25 pm Up
How did u do the indicators in your wiring loom mate? i think they are negative earth as standard. my wiring guy is all worried about it
macj
PostPosted: Wed Feb 16, 2011 3:51 pm Up
Tell him to buy a power probe...... I think you may be right about the negative feed..... I built mine from scratch and built a fuse board with a relay for the indicators..... that said, I think your sparky should suss it out, Find the common feed to the switch and put power to it... then find the power outs from the switch wiring with lights, fogs and flashers etc.
macj
PostPosted: Tue Feb 22, 2011 12:47 pm Up
Just found this picture on the net.... quite good
sportstock.photoshelte..._Po8jnRxaI
PostPosted: Tue Feb 22, 2011 2:51 pm Up
That looks really good Mac
Page 16 of 33
