Posted: Sun Feb 15, 2015 3:51 pm |
macj wrote: |
Addaz wrote: |
Thank goodness them stickers are off!
If you do chose steve, let me know how it goes! |
Was it Track n Road or something similar? That's where its going |
Yes it was mate, let the steves know im coming back for more power
Just a word of warning, one steve you have to take with a pinch of salt, as he is quite abrubt but those two are so bloody smart!
Also make sure your lambda is free any easy enough to get to for the mapping, as they prefer a direct screw in lambda
| Team Impossible Possible
Posted: Sun Feb 15, 2015 5:15 pm |
They will have to do the AFR up its RRRs as its a race car
As for a smart RRRs..... they not met me yet. They will get their instructions and will have to follow it...... full stop or no money.
I only like to deal with pro`s as it has cost a lot so far
Posted: Sun Feb 15, 2015 5:52 pm |
Well i can tell you now mate, just by the completely different approaches track and road took to how the others did shows you how much better they are.
As for one example the other firm over clocked the preset injector amount apposed to setting it correctly and working each fragment on the map correctly. And they also bedded the engine in slowly apposed to foot to the floor straight away and then saying my engine has gone bang
Posted: Thu Mar 05, 2015 10:48 am |
Well I have had to sack the last manager and here is the new one.
This change has come because Steve at Track`n`road wanted this ECU as he thinks it will produce better results
Posted: Thu Mar 05, 2015 2:56 pm |
How much you want for the old management?
Posted: Thu Mar 05, 2015 3:04 pm |
Andy83 has initial dibs on it ATM. But if he decides not to take it we can talk
Posted: Thu Mar 05, 2015 3:11 pm |
macj wrote: |
Andy83 has initial dibs on it ATM. But if he decides not to take it we can talk |
DAM HIM
Already have one megashitter ECU, might as well have another
Posted: Sat May 23, 2015 3:52 pm |
After what seems like an eternity I got the call from Track`n`Road to say the car was mapped successfully. The final result was reasonably impressive.
209HP at the wheels and 167ft/lb torque
The power starts around 4500rpm and a limiter set at 8000rpm
Roll on FCS
Posted: Sat May 23, 2015 4:15 pm |
That's great news after your misfortune.
Going to be good to see it again. Just hope I can go
