Online Now [651]:
Visitors: 650
Today: 193365
Total: 145672172
Forums › The Car › Solved 206 Problems › big problem with lights
Forum Index › Solved 206 Problems
kamikaza_90
PostPosted: Sat Sep 18, 2010 6:40 am Up
3 days ago i started my car and when i switch on lights i have seen that something is very wrong! Mad When i switch only short light all four bulb start to light but left headlight just dim..on other side short beam works fine exept long beam stay dimmed. Shocked
When i hit long beam left headlight stop working and only right works.
Do you have idea what is the problem?
Uploaded with ImageShack.us
peugeot 206 2.0hdi
purrjoe
PostPosted: Sat Sep 18, 2010 7:19 am Up
Probably the earth wire that is bolted to the body just behind the headlight has become corroded and so not earthing properly.
Take the bolt out, clean it and the electrical connector on the wire and also the bodywork around the hole with some abrasive paper.
That will almost certainly do the trick.
bugawuga
PostPosted: Sun Sep 19, 2010 1:58 am Up
Bingo. The earth is bolted to the chasis behind the passenger headlight. (literally just behind it).
kamikaza_90
PostPosted: Sun Sep 19, 2010 4:11 am Up
I solve my problem! Wink Reason why my lights were dimmed is jack with 3 wires on left headlight,contact was very bad and i just spray wd 40 and take off plastic protection around those 3 wires so now is more flexibile.
But it took me 1 hour to find a problem! Smile
Thank to all of you for help Smile
peugeot 206 2.0hdi
