Online Now [56]:
Visitors: 55
Today: 659
Total: 106046543
Forums › The Car › 206 Problems › Serious starting issues!
LilLew
PostPosted: Wed Oct 27, 2010 4:58 am Up
dannyboiii wrote:
hey guys, since my last post i have bought and fitted a new fuel/petrol filter and also cleaned the idle control valve. Also filled the tank and used a bottle of STP fuel injector cleaner. It seems to be getting worse as is the weather. Ive figured that if when it turns over i floor the revs (waking everyone up within the next few blocks) then it wont stall.If i try to start it without hitting the accelerator it stalls. As ive said before this is only usualy first thing in a morning or if i havent driven it for a few hours. Once i get it started i dont have any problems. Also had diagnostic checks on it and found nothing, friend on mine suggested changing the throttlebody? Im stuck guys =/
Have you tryed disconnecting your lambda sensor i had exactly the same thing happen on my corsa
2003 Pug 206 2.0 GTI 180
dannyboiii
PostPosted: Wed Oct 27, 2010 6:23 am Up
Tbh mate I'm not sure where the lambda sensor is lol can't find it in the Haynes manual.
2001 1.4 8v petrol
dannyboiii
PostPosted: Wed Oct 27, 2010 6:25 am Up
Nevermind dude I found it, oxygen sensor Smile
2001 1.4 8v petrol
dannyboiii
PostPosted: Wed Oct 27, 2010 6:39 am Up
Gotta wait for the engine to cool before i can try the lambda sensor, also gave peugeot a call, said it sounds like it could possibly be the starter motor but they will give me a call back in a while.
2001 1.4 8v petrol
macj
PostPosted: Wed Oct 27, 2010 6:40 am Up
replace your engine temp sensor. Especially if you have found your temp guage not showing correct reading lately. It may be that it is not fuelling your car on cold start properly and this is detected by the ETS. Worth a shot
dannyboiii
PostPosted: Tue Nov 02, 2010 3:30 pm Up
Hi guys, I've tried disconnecting the lambda sensor and no luck, got a new ETS to try and if that don't work gonna go get it plugged in somewhere n see if it throws up any codes :/ really annoying me now!
2001 1.4 8v petrol
PostPosted: Tue Nov 02, 2010 3:34 pm Up
Are you using NGK spark plugs?
dannyboiii
PostPosted: Wed Nov 03, 2010 7:03 am Up
I cant remember the name when i put them in but i think they are tbh, why? Smile
2001 1.4 8v petrol
Danny.
PostPosted: Wed Nov 03, 2010 7:10 am Up
206 dont like NGK Spark plus can cause problems to the Engine. Swap them out for Bocsh ones Smile
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
dannyboiii
PostPosted: Wed Nov 03, 2010 7:22 am Up
Oh right, but would that not cause missfires? and could it be causing my starting problem?
2001 1.4 8v petrol
Danny.
PostPosted: Wed Nov 03, 2010 10:57 am Up
Not sure mate. But its a cheap fix they're about £3 each Smile £12 and it could fix it Very Happy
Kersh
PostPosted: Wed Nov 03, 2010 11:25 am Up
not sure if that will work mate, ive got v similar problems and im running super 4's
(FYI if youve got the same problem as me its not sparks, coilpack, MAP sensor or a dirty ICV.. i found out the expensive way ha)
Member number: 36
dannyboiii
PostPosted: Wed Nov 03, 2010 6:03 pm Up
lol sorry to be nosy but what resolved your problem? Smile
2001 1.4 8v petrol
PostPosted: Wed Nov 03, 2010 6:04 pm Up
You had a diagnostic scan?
dannyboiii
PostPosted: Wed Nov 03, 2010 6:31 pm Up
mechanic that checked it over first time said he had a diagnostic scan done and said it gave a few codes but he "cleared them" no idea what codes they were though so was thinking about taking it to have it done myself so i can see these codes.
2001 1.4 8v petrol
Page 2 of 3
