Latest: tbafonso
Overall: 17130
Online Now [122]:
Visitors: 122
Today: 45179
Total: 104626924
Forums › The Car › 206 Talk › Is there any demand for these?
PostPosted: Wed Oct 20, 2010 1:59 pm Up
Not sure if this in the right section or not, trying to find out if there is a demand for these factory headunits and 6 disc changers out of the 206 gti's 137 version as I will soon have mine for sale as soon as I get my new stereo fitted
PostPosted: Wed Oct 20, 2010 2:05 pm Up
probably not unless you find someone returning to standard, youd probably be best off on ebay Smile
PostPosted: Wed Oct 20, 2010 2:31 pm Up
Somebody with a lower spec 206 might be interested...
MRyan89
PostPosted: Wed Oct 20, 2010 3:03 pm Up
Which headunit have you got? Its a different cd changer if i remember right depending on which hu you have
PostPosted: Thu Oct 21, 2010 11:43 am Up
It's a blaupunkt radio/cassette headunit with clarion 6 disc changer
