Latest: Beduff1977
Overall: 17134
Online Now [1309]:
Visitors: 1308
Today: 85785
Total: 106946284
Forums › The Car › 206 Talk › Manifold fix in situ Gti
JG220
PostPosted: Fri Oct 22, 2010 1:25 pm Up
I found a lot of posts on the vibration from these.
Today i dropped the exhaust and welded the manifold whislt in place.
Picture of the access
i arc welded along the joins and a couple of spots to the side.
Doesn't make a sound anymore Smile
Its a 30min job, unless you fall out with the lamba's and the daft connection from the manifold the dowpipe. It took a couple of hours in the end.
Now onto the servo.
www.mangoracing.co.uk
PostPosted: Fri Oct 22, 2010 1:42 pm Up
will it be a bit dangerous to do the welding while the manifold is still on the car?
JG220
PostPosted: Fri Oct 22, 2010 1:47 pm Up
No, not as hot as exhaust gasses. Absolutely fine.
I didn't even bother disconnecting battery.
PostPosted: Fri Oct 22, 2010 2:08 pm Up
i am more worry about the current might "cook" the ecu and bsi.
but anyway it sounds fine to you and i guess it does save a lot of time and work to do it in your way.
