Online Now [288]:
Visitors: 287
Today: 10208
Total: 143208423
Forums › The Car › 206 Talk › will 306 alloys fit on 206?
Sophia-206-GT
PostPosted: Sun Oct 24, 2010 8:23 am Up
will 17" alloys that were on a 306 fit on my 206? thanks
PostPosted: Sun Oct 24, 2010 8:24 am Up
Yeah should do, are the Pug ones?
Lecktorious
PostPosted: Sun Oct 24, 2010 8:28 am Up
Trade Rating: +59
Doubtful, there aren't many, if any OEM 17's in that offset.
EDIT: You'll probably have issues with clearance, the 306 offset is lower so I'll imagine you'll be fouling the outer arches.
'98 Nile Blue 306 GTi 6
Sophia-206-GT
PostPosted: Sun Oct 24, 2010 8:31 am Up
they arent standard peugeot alloys, alloys are so confusing
Brian
PostPosted: Sun Oct 24, 2010 8:35 am Up
Trade Rating: +31
If the 306 they come off of had spacers you will be fine if it didn't have spacers on it - refer to G's post again!
mrjonahlovetts
will probably fit with low profiles that are not too wide 195 45 17?
mrjonahlovetts
Brian
PostPosted: Sun Oct 24, 2010 8:57 am Up
Trade Rating: +31
It's the spacing from the hub that's the issue, not the diameter of the wheel as such. You'd need to tell us the offset of the wheels you want to put on really. It can be anything if it's aftermarket....you need it to be et28/et25.
gavstar
PostPosted: Sun Oct 24, 2010 11:55 am Up
I had some TSW's that were on my 306...went to fit em to the 206 just sop I had alloys as opposed to steels and they fouled the arch by about 2 inches...pullable at least
