Latest: tebas93089
Overall: 17179
Online Now [100]:
Visitors: 98
Bots: 2
Today: 12315
Total: 138206045
Forums › The Car › 206 Talk › Using a 2nd hand ECU
PostPosted: Wed Oct 13, 2010 2:00 pm Up
So here's a question...if I got hold of a 2nd hand ECU and simply plugged it in obviously the engine would run but what else wouldn't work?
I'm thinking if my original ECU is fried in some way by dodgy wiring up can I fit a 2nd hand ECU? My Omex runs the engine but will the standard Peugeot ECU still run my clocks and fans etc?
Teebag
PostPosted: Wed Oct 13, 2010 2:03 pm Up
will need coding to the bsi aswell
my garage inc mod list:
- Antix
PostPosted: Wed Oct 13, 2010 2:07 pm Up
Yeah, or just get the bsi with the ecu and it should be ok
dturbopeck
you could try it but am sure its the imobaliser thats the problem, think it needs to be unlocked
PostPosted: Wed Oct 13, 2010 2:12 pm Up
It's not multiplexed (So I don't think there's a BSI) and the Omex runs the engine and bypasses the original imobiliser.
PostPosted: Wed Oct 13, 2010 2:14 pm Up
Yeah there's a BSI on all 206's mate, they just don't do as much on the non-plexed. If you look at the drivers fuse box, the bottom row of fuses are attached to the BSI, if you stick your head under you can see the box
T_bandery
PostPosted: Wed Oct 13, 2010 2:30 pm Up
All GTis use the BSi
GazRG
PostPosted: Thu Oct 14, 2010 10:08 am Up
I was going to reply to Edward's post - as Lee says, every 206 has a BSi.
'98 MGF 1.8i
Team: ex-206 owner
colinn
PostPosted: Thu Oct 14, 2010 11:00 am Up
I think you would need ecu, bsi and key transponder - which is how they are normally sold - all together
st3v3n
PostPosted: Tue Oct 26, 2010 11:50 am Up
You should use the omex to run your fan really. I'd trust that more than the original ECU if the omex is running everything else. (blue wire with black trace)
ICE goes in drinks. NOT in cars.
PostPosted: Tue Oct 26, 2010 11:54 am Up
I'm going to wire in the Omex soon. I'll keep the original ECU running the low speed fan for the airconditioning (if it stops working it's no big deal) and wiring the Omex into the original Peugeot high speed relay. Hopefully. Anybody see any problems with that? I'm currently thinking the original ECU will just control the trigger to the relay and not the actual power supply.
PostPosted: Tue Oct 26, 2010 2:50 pm Up
I'm sure there is a resistor inbetween the relays and fan, that goes to the ECU
