Latest: Beduff1977
Overall: 17134
Online Now [640]:
Visitors: 639
Today: 136946
Total: 108072088
Forums › The Car › 206 Talk › torsion bar removal tool
charlie-52
PostPosted: Tue Nov 09, 2010 5:38 pm Up
im in talks with a guy who works with metal he makes a removal tool for the Alfa romeo, so ive asked him about one for a 206 just after how much interest there would be for one, it will work the same way as the 30mm socket .... so would you be interested in one?
they wont be expensive either!! around the 20 pound mark + p&p
PostPosted: Tue Nov 09, 2010 6:00 pm Up
Wouldn't mind seeing a pic,
Rich196
PostPosted: Tue Nov 09, 2010 6:21 pm Up
it would work like a 30mm socket, so hes going to make you a 30mm socket is there any point?
TT 225 + a bit!!
Audi TT 225 + a bit Wink
charlie-52
PostPosted: Wed Nov 10, 2010 2:01 am Up
im not totaly sure hes going to send me pictures i gess the part which works as the 30mm socket will be threaded
PostPosted: Wed Nov 10, 2010 3:54 am Up
Interested.
Big_Rich180
PostPosted: Wed Nov 10, 2010 3:58 am Up
Guess it would be like this cgi.ebay.co.uk/Peugeot...3f049b021d
LilLew
PostPosted: Wed Nov 10, 2010 5:01 am Up
Yep i guess just like that i am gonna invest in one
2003 Pug 206 2.0 GTI 180
PostPosted: Wed Nov 10, 2010 6:44 am Up
why do you need that??
Big_Rich180
PostPosted: Wed Nov 10, 2010 6:46 am Up
I'd guess its easier than hammering it out.
If it works..
PostPosted: Wed Nov 10, 2010 6:49 am Up
Nothing is easier than using a sledge hammer. Seized torsion bars need brute forced not delicate little tools.
PostPosted: Wed Nov 10, 2010 6:50 am Up
If it works..
What He Said
Big_Rich180
PostPosted: Wed Nov 10, 2010 6:51 am Up
Seabook wrote:
If it works..
What He Said
Personally i wouldnt bother at all, id get some one else to do it Laughing
PostPosted: Wed Nov 10, 2010 9:54 am Up
True hammer is Easier, tryed the bolt method once and snapped the bolt so never tryed it that way since.
charlie-52
PostPosted: Thu Nov 11, 2010 2:18 am Up
how about if i had a a very high tensile bar made with an m10 thred on one end a large nut half way down (welded into place) to wind it into the torsion bar and a flat surface on the other end to hit with a BIG hammer, atleast then you wont damge the threads while hitting the torsion bar
PostPosted: Thu Nov 11, 2010 2:22 am Up
Sounds like a idea, I normally push a smaller bolt into bar and hit on that (if you use right size the head gets disformed and can't get it out)
Can you draw a diagram?
