![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › Pug reliability. |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Thu Nov 11, 2010 1:46 am |
I've had mine for obver 7 years now. It's was very well looked after and not a single problem happened except for needing a repair to a broken connector in the speedo wiring.
| | ![](images/spacer.gif) |
Posted: Thu Nov 11, 2010 1:52 am |
mikey2uk wrote: |
deebom wrote: |
No, I dont think I have. How easy are they to do on Pugs? |
Depends what engine you have but it would be best to have it done fairly soon as you have no history of it being changed.
Whats the mileage? |
The odometer doesnt work, but according to the MOT it's got about 90.000 on it. It's 1.4 GL or something. It's got Aircon and a CD changer in the boot. Hopefully it's cheaper and easyer that my Forester wich is £180 for a cambelt kit.
Posted: Thu Nov 11, 2010 2:12 am |
Edward wrote: |
I've had mine for obver 7 years now. It's was very well looked after and not a single problem happened except for needing a repair to a broken connector in the speedo wiring. |
'We' too have had ours for 7 years, and it's 10 years old. The biggest problem it has had to date is a brake cylinder issue due to lack of service. Just before that (literally days), it also had a front end bump.
It's overdue another service, but is still going strong with no issues other than self-made ones (audio related, and internal condensation caused by removal of door linings).
Posted: Thu Nov 11, 2010 4:43 pm |
I am new to 206 ownership compared to many on this site. But in the 13 months I've owned my Quiksilver I have had no problems whatsoever. Reliable transport is a necessity for me to travel to work etc because public transport is virtually non existent where I live.
| ![](themes/base/images/forums/otr.gif) |
