Online Now [117]:
Visitors: 116
Today: 11919
Total: 143138427
Forums › The Car › Solved 206 Problems › brake light
brake light
hazzer1501
PostPosted: Tue Nov 16, 2010 6:15 pm Up
my brake light has gone, i have a new bulb for it , just needs changing , just wondering if there is anything that shows you how to do it on here????
thanks Very Happy
haz!!!!
DeadEyePaul
PostPosted: Tue Nov 16, 2010 6:18 pm Up
Just lift the boot up and underneth the light there are two bolt nuts to undo then lightly tap the two bolts (the bolts are attached to the light) soon as the bolts disappear the light can be removed
DeadEyePaul
PostPosted: Tue Nov 16, 2010 6:39 pm Up
If it's the main brakes look behind the carpet there are twist lock bolts that can be undone with your fingers there's 1 per side and the light will simply slide out
