Online Now [229]:
Visitors: 228
Today: 19971
Total: 142926093
Forums › The Car › Solved 206 Problems › head gasket gone or thermostat???
d00b
PostPosted: Tue Nov 09, 2010 7:55 am Up
HELP DAMSEL IN URGENT NEED PLEASE can anyone give a bit of info
ive had my pug verve 206 1.4 2005 for 5 years now and have had no problems up until yesterday when the temp went right up and my stop light was flashin and beepin.
i opened the bonnet and my water bottle was buibblin so i let it cool topped up with water (OIL WAS FINE) and kept my internal fans on and it kept cool till i got home.
can anyone tell me the symptoms for a blown head gasket or any info that could help me please
thanx ju
wardie_206
PostPosted: Tue Nov 09, 2010 7:57 am Up
Did u notice any water leaking from anywhere at all??
panason1c
PostPosted: Tue Nov 09, 2010 7:58 am Up
I would remove and check the thermostat first which might have failed before suspecting the head gasket.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Tue Nov 09, 2010 8:01 am Up
Check the oil filler cap for emulsification on it. (or called mayonnaising as that's what it looks like). If you have, that's a good indication of a blown headgasket.
d00b
no wardie no water leakin anywheres
ive just ordered a thermostat is this a common fault in pugs?
crazy mazey carz
d00b
PostPosted: Tue Nov 09, 2010 8:03 am Up
thanks E5GDM there's none of that either Smile
crazy mazey carz
PostPosted: Tue Nov 09, 2010 8:09 am Up
Looking good for a dodgy thermostat.
d00b
PostPosted: Tue Nov 09, 2010 8:11 am Up
thanks guys your all stars been doing my girly nut in thinkin me cars had it Smile xxmwahxx much appreciated x ill let u all know when the thermostats delievered tomorro x
crazy mazey carz
wardie_206
PostPosted: Tue Nov 09, 2010 8:13 am Up
no probs :). as E5GDM said sounds like a dodgy thermostat in that case Smile
d00b
PostPosted: Wed Nov 10, 2010 4:25 am Up
had my gasket checked last nite and its OK!!!!!!!!! YEAY it now may be the thermostat or water pump thank god thank you all for your help much appreciated !!!!!!
crazy mazey carz
PostPosted: Wed Nov 10, 2010 4:36 am Up
Might be water pump in which case do the cam-belt while you're at it.
d00b
PostPosted: Sun Nov 14, 2010 2:34 pm Up
thanks for all the help peeps probably is now solved it was the thermostat and my d00b mobile is running like the beast he is cheeeeeeeeeeeeeeeerrrrrrrrrrrrrs xxxxx
crazy mazey carz
