Online Now [110]:
Visitors: 109
Today: 64408
Total: 105327676
Forums › The Car › 206 Talk › Dial Faces
Dial Faces
Uz
PostPosted: Mon Nov 22, 2010 6:26 am Up
Does anyone know if I can use dial faces with resting pins on them in a multiplexed dial..?
My XSi has a white face with no resting pins but want to change it to black but the one Jamie (on my wanted thread) is offering me has resting pins and I want to check.
Danw_VVT
PostPosted: Mon Nov 22, 2010 6:31 am Up
i dont see why not? the needles drop when all circuits are off in the multiplexed. so it will just stop them dropping?
imo cant see a probably with it.
biskwits
Golfguy206
PostPosted: Mon Nov 22, 2010 6:49 am Up
am I not right in thinking that the stick on dial faces (if they are designed for the dials with resting pins) just have a small hole for the pin to go through??
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
Mr_Cellexe
PostPosted: Mon Nov 22, 2010 2:44 pm Up
said it before Wink
you can remove the pins! non plex or plexd, the dials should still respond in the same way as they are analogue.
