Does anyone know if I can use dial faces with resting pins on them in a multiplexed dial..?
My XSi has a white face with no resting pins but want to change it to black but the one Jamie (on my wanted thread) is offering me has resting pins and I want to check.
am I not right in thinking that the stick on dial faces (if they are designed for the dials with resting pins) just have a small hole for the pin to go through??
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
