Posted: Sat Nov 20, 2010 11:47 am |
Hi guys, I got some 180 wheels on my car, not sure on the size tyres but i assume all tyres should be the same, what i'm wanting to find out is what the pressure should be?
Posted: Sat Nov 20, 2010 11:56 am |
Trade Rating: +59
Well if you have one Vortex with a 16" tyre fitted then your in trouble
Tyre pressures will be the same as before.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Nov 20, 2010 12:00 pm |
there 17" tyres just don't know the offset whether there 40 or a 35 etc
Posted: Sat Nov 20, 2010 12:02 pm |
Trade Rating: +59
| MattyP wrote: |
| there 17" tyres just don't know the offset whether there 40 or a 35 etc |
Why would the tyres have an offset
Posted: Sat Nov 20, 2010 12:05 pm |
The alloys have the offset PCD and all that. The tyres will be slightly diffrent depending on what youve put on i think its 32PSI ill double check though
Posted: Sat Nov 20, 2010 12:06 pm |
32 Front
30 Rear
Posted: Sat Nov 20, 2010 12:11 pm |
| brad-morris wrote: |
32 Front
30 Rear
Cheers Brad
Posted: Sat Nov 20, 2010 12:50 pm |
No problem
Posted: Sat Nov 20, 2010 5:48 pm |
i run mine at 33psi all round thats what it says on my door pillar sticker thingy
Posted: Sat Nov 20, 2010 6:16 pm |
Usually says on the tyre sidewall the Max PSI they can run, I usually go a few PSI under the max
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Sat Nov 20, 2010 8:23 pm |
I go 2.4 bar all round
Posted: Sun Nov 21, 2010 7:07 am |
| rttam wrote: |
i run mine at 33psi all round thats what it says on my door pillar sticker thingy  |
Mine says 2.2 bar whatever that is! I normally go with psi
| Onyx Black 2005 206 GTi 180, 44K miles, FSH, standard (apart from a K&N panel air filter, Angel Eyes and groovey rear & groovey front holy discs!) | |
Posted: Mon Nov 22, 2010 3:33 pm |
| namgaj wrote: |
| Usually says on the tyre sidewall the Max PSI they can run, I usually go a few PSI under the max |
find your tyres always wear in the centre and have a really hard ride by any chance?
Posted: Mon Nov 22, 2010 4:16 pm |
| rttam wrote: |
| namgaj wrote: |
find your tyres always wear in the centre and have a really hard ride by any chance?  |
not nessarily, it all depends on which tyre you got.
