Posted: Thu Nov 25, 2010 1:46 pm |
wheres the best place to wire a gauge from the dash to the battery?
where can i go through the bulkhead?
Posted: Thu Nov 25, 2010 1:47 pm |
are you wanting it to go off with the key or are you wiring a switch into it?
Posted: Thu Nov 25, 2010 1:51 pm |
ExoVyper wrote: |
are you wanting it to go off with the key or are you wiring a switch into it? |
depends how easy it is to hook it to the ignition...
Posted: Thu Nov 25, 2010 1:53 pm |
nakednakeddave wrote: |
ExoVyper wrote: |
depends how easy it is to hook it to the ignition... |
absolute piece of pi$$ mate you just remove the bottom cover from your steering column and it's there. you just need a multimeter to find which wire it is, a simple scotch lock later and your sorted pal
Posted: Thu Nov 25, 2010 1:55 pm |
balls one thing i don't have is a multi meter....although i am hooking up the volt gauge...
Posted: Thu Nov 25, 2010 1:58 pm |
even better!
easiest way to do it is grab a stanley knife and touch the volt meters wire to it then cut gently into it's either a yellow or a red wire i think... the stanley is an easy way without stabbing your fingers of getting the right wire
remember to use the ignition though! i have gotten the wrong wire before only to find out after i put all the covers back on T_T
Posted: Thu Nov 25, 2010 1:59 pm |
but grab yourself a cheap multimeter as they are invaluable
Posted: Thu Nov 25, 2010 2:00 pm |
ExoVyper wrote: |
but grab yourself a cheap multimeter as they are invaluable  |
used to have one but it went walkies and never appeared...
but cheers for the help
Posted: Thu Nov 25, 2010 2:24 pm |
ExoVyper wrote: |
i know that feeling was typical at my old work
no problem pal i'm always here to help when i can ^_^
