Posted: Tue Nov 23, 2010 12:25 am |
Needing to replace rear disks this week, Just wondering about getting the piston back in. Can i just use a pair of long nosed pliers? I have done this before, not sure what the 206 is like.
| Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. | |
Posted: Tue Nov 23, 2010 12:56 am |
Yup, definitely mate. I used a thick long screw driver
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Tue Nov 23, 2010 2:57 am |
Yep, I too used a screwdriver when doing them on my old 206.
Posted: Tue Nov 23, 2010 4:10 am |
i will be replacing mine this week , ive found a seller on ebay who will do a good deal on discs and pads all round. it was just the tool i was worrid about but if you can wind them back in then its a bonus
Posted: Tue Nov 23, 2010 10:04 am |
Chears guys.
Posted: Fri Nov 26, 2010 1:37 am |
if they are the same set up as Renault use a g clamp.
Wile tightening the gclamp turn the piston clockwise wile applying pressure.
The piston will go back in so repeat the prosess till its fully back in.
Hope that helps.
