Latest: tbafonso
Overall: 17130
Online Now [188]:
Visitors: 187
Today: 16398
Total: 102539199
Forums › The Car › 206 Talk › Bolt and Socket size
Jayyy1989
PostPosted: Mon Nov 29, 2010 8:17 am Up
what size bolts are the Peugeot alloy wheel bolts? What sized socket do i need for them? My wheel brace is too big for the bolts on the car :S doesnt grip to the bolt
EuroPeugeot
PostPosted: Mon Nov 29, 2010 8:20 am Up
Im guessing 17mm..
Antknee
PostPosted: Mon Nov 29, 2010 8:22 am Up
Think the standard ones were 17mm across flats, but my alloy ones are 19
PostPosted: Mon Nov 29, 2010 1:49 pm Up
GTi bolts have 19mm heads.
PostPosted: Mon Nov 29, 2010 2:37 pm Up
Sounds like they are 17mm bolts and you're using a 19mm socket.
Unless you're been a dip s**t and just tried it on the locking nut Laughing
MNARAA
PostPosted: Mon Nov 29, 2010 4:12 pm Up
Time for a visit to a scrappy for one that fits. Chances are they've got a huge pile of them and will let you have one for next to nothing (or even nothing as was the case when i needed one). Just try till you find one that fits.
There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake.
Nitrox121
PostPosted: Mon Nov 29, 2010 4:45 pm Up
invest in a proper breaker bar and socket Wink money well spent!
Die Hard Member - Back For Round 2 -
New Car: BMW 318 Ti Compact M Sport
Jayyy1989
PostPosted: Tue Nov 30, 2010 11:14 am Up
Yeah just went and got one, they are 17 mm Bolts on alloy wheels, are they even suitable for Scirocco wheels? I get vibration from the steering wheel when i go over 80mph, would bigger bolts fix this or not make a difference?
Jay Kane
PostPosted: Tue Nov 30, 2010 11:20 am Up
Makes no difference. Just get the balancing checked.
