Latest: tbafonso
Overall: 17130
Online Now [150]:
Visitors: 149
Today: 68300
Total: 102912088
Forums › The Car › Request a how-to › how to adjust clutch pedal travel GTI138?
Forum IndexRequest a how-to
track370z
PostPosted: Wed Dec 01, 2010 9:48 pm Reply with quote Up
2003 GTi138, I want to reduce the amount of clutch pedal travel. My previous car (350z) could be adjusted from the footwell, right on top of the clutch pedal. I have had a quick look on the Pug and cannot see anything like this.
Thanks in advance.
For reference, this is how it was done on the Z (pics in link)
www.nicoclub.com/archi...-370z.html
2003 Peugeot 206 GTI 138HP
Custom Intake using standard airbox
Straight through perfromance muffler
Griffith Engineering Quick Shift
Group N uprated gear linkages
Big_Rich180
PostPosted: Thu Dec 02, 2010 3:35 am Reply with quote Up
Im not sure you can on a 206.
PostPosted: Thu Dec 02, 2010 3:44 am Reply with quote Up
A company is offering a discount to 206info, they sell pedalboxes, may be useful if its for a track car.
206info.co.uk/Forums/v...19819.html
PostPosted: Thu Dec 02, 2010 6:32 am Reply with quote Up
You can't adjust the pedal.
track370z
PostPosted: Thu Dec 02, 2010 2:51 pm Reply with quote Up
I recall reading that you may be able to adjust the free play?
I find it difficult to believe that the pug has no means to adjust the clutch pedal height.
  Quick Reply
Username:
Message:
Quote the last message
