Latest: airmastertapes
Overall: 17133
Online Now [495]:
Visitors: 494
Today: 71379
Total: 106783239
Forums › The Car › 206 Problems › anti poulution fault 206 gti 2002
krowy
PostPosted: Fri Dec 03, 2010 9:33 am Up
my gti is havin problems on these cold mornings its displaying anti poulution fault. some times catalyst fault. @ engine management light comes on. car runs bad splutters after puting car on diagnostics it comes up with multiple miss fire after wiping fault car runs great until the next time the weather is beloww freezing any ideas what it could be ? also would a coil pack from a 2000 gti fit mine ok mine is2002 thanks in advance 4 your help kind regards krowy ,p.s merry christmas
PostPosted: Fri Dec 03, 2010 9:39 am Up
It can be a number of things but most likely the 1st Lambda sensor (pre cat)
PostPosted: Fri Dec 03, 2010 10:02 am Up
Wink
Stewart
PostPosted: Mon Dec 06, 2010 4:20 am Up
I am also looking to fit a 2000 Coil pack onto my 2004 Gti. Does anyone know if this will work?
Also how do you get to the hydraulic tappets?
Peugeot 206 Gti
PostPosted: Mon Dec 06, 2010 5:44 am Up
Confused
krowy
PostPosted: Mon Dec 06, 2010 3:47 pm Up
seems like a bit of vasaline spread over the coil pack plug has solved the problem at the mo think the damp air was causeing the problem its not played up 4, 3 days at the mo so fingers crossed its worth a try if your havin the same problem
troy
PostPosted: Mon Dec 06, 2010 3:52 pm Up
always good to keep abit of vas handy in your car see =]
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
akgti180
PostPosted: Sun Dec 12, 2010 7:20 pm Up
I had the same fault code and problems on my 180 only a few weeks ago... just got it back from mechanic after he replaced the battery. Found that the main clamp on the pipe that goes into the airbox was loose. Tightned this up, fired her up and all is well.
You might find that a particular fault code may relate to multiple different problems, so don't take my word for it. Double check that everything relating to you air intake is sweet.
Pug GTI 180 - Downunder
Bigbenj_08
PostPosted: Mon Dec 13, 2010 1:48 am Up
I had this one morning last week when it was reeeeeally cold (-13 at night).
Phoned my Peugeot mechanic back home and he told me to give it 10 more starts from cold before going to get it plugged it and its probably ice/grit getting into the lambda sensor.
Low and behold, the next day when it was't as cold the fault disappeared and hasnt come back since!
Aegean Blue 1.6 16v Sport
