Forums › The Car › 206 Problems › window wipers not working |
Posted: Mon Mar 14, 2016 1:42 pm |
hi
my window wipers on a 206 2003 1.6 are not working rear wiper and washer works and front washer jets work but no wipers any help would be great I have checked fuses but all are ok I was told comms unit on the steering wheel/stalks
Posted: Tue Mar 15, 2016 9:36 am |
Hey Johnny,
I recently changed my windscreen wiper motor and rods after buying a set off a breaker for £15. It was a brave bit of work to disconnect and get everything out but I managed it in the end and they're now working properly.
The motor itself could be what has broken or it could be something else, but this video from EricTheCarGuy was a great help to me when trying to find out why mine were broken.
Posted: Wed Mar 16, 2016 7:01 am |
Unplug the windscreen motor plug,and get an Volt meter,set the stalk on the working order,if you got a reading,then the stalk is working,and the motor is not,if no reading,then the motor is good,and stalk needs to be replaced.
