Latest: Puggingalong
Overall: 17129
Online Now [76]:
Visitors: 75
Today: 8755
Total: 100983340
Forums › The Car › Solved 206 Problems › Quikky won't start :(
kirsteyjames
PostPosted: Tue Dec 07, 2010 3:42 pm Up
Took my car in for MOT today and it failed on anti roll bar linkage!! Brought it home and fitted a driver side driveshaft (it was clicking) and a new bar!! Yay all done for MOT! Tried to start the car but it wont turn over Sad Put jump leads on still no luck! Tried to bump start still no good! The starter motor and battery are ok! It was quite low on petrol and i thought as it had been up on one side the petrol werent coming through (has happened when iv been parked on a hill with little petrol lmao) so My friend took the air filter off the engine and sprayed some lynx as i was trying to turn it over and it fired the engine so off we went to get petrol from the garage! So he thinks that for some reason its something to do with the petrol :S
Anyone have any idea what this can be?
oh and also when im holding the key to turn it over the engine management light flashes (not sure if it normally does this as ive never tried turning it over for so long)
troy
PostPosted: Tue Dec 07, 2010 4:31 pm Up
first of all i would put more than a fiver in there just to be sure, first thing to do is turn the ignition switch on and you should hear a buzzing noise from under the rear, this will be the fuel pump primming, it should go for about 3-4 seconds and then stop, if this isnt making a noise then check for a live.
the flashing eml could be indicating that there is a managment fault present so that would be my next port of call if the fuel pump is running
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
kirsteyjames
PostPosted: Tue Dec 07, 2010 4:44 pm Up
cant hear the fuel pump :S there's 1/4 of a tank in there now!
PostPosted: Tue Dec 07, 2010 4:46 pm Up
You got a big red fuel inertia button near the battery? check that if you have
kirsteyjames
PostPosted: Tue Dec 07, 2010 5:07 pm Up
Thanks Lee Will have a go 2moro Smile had to leave my car at my friends garage Sad
kirsteyjames
PostPosted: Wed Dec 08, 2010 3:56 am Up
Its not the button! Any other ideas what it could be! My friend reckons something is stopping the fuel pump working! Is there any snesors or anything to check?
gixxerkev
PostPosted: Wed Dec 08, 2010 5:40 am Up
How about a fuse for the fuel pump?
An Ex '03 1.4 GLX driver, German technology all the way now.
kirsteyjames
PostPosted: Wed Dec 08, 2010 8:08 am Up
Fixed Smile knocked a wire out that controls the injectors when fitting driveshaft haha
