Latest: S2cgm
Overall: 17178
Online Now [208]:
Visitors: 208
Today: 85525
Total: 137616139
Forums › The Car › 206 Problems › Horn issues!
Horn issues!
JJ0063
PostPosted: Fri Dec 10, 2010 3:58 pm Up
Hi all
Right i'm puzzled!
My horn doesn't work.. i checked online & it failed its last MOT for it not working.. then passed.. so must have been fixed.. but now not working again.
the actual horn works (wired it to the battery and its fine) but there's no power getting to it.
i've taken the airbag off and the wiring looks fine.. even connected the battery back up without the air bag on & touched the red/green wires together to see if it was the contacts on the air bag.. still nothing
checked with a multimeter & there's nothing, havent got a manual or a fusebox diagram but all the fuses in the engine bay and under the dash LOOK ok, but i'm not sure what fuse it is 100%?
Its a 99 V plate 1.4 lx.. preplexed?
any help please?
Cheers!
troy
PostPosted: Fri Dec 10, 2010 4:10 pm Up
panel under your steering wheel held on witha plastic screw, it has a diagram of which fuse is which on the back of it.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
Bassline_Toad
PostPosted: Fri Dec 10, 2010 4:53 pm Up
is it earthed correctly? Might explain why you're not getting a reading on the multimeter when its connected to the battery, check for between the fuse and before your horn once disconnecting the from the battery, using the ohm setting on the multimeter. if it comes back with something (expect something like 0.04 ohms), showing it's not an open circuit
JJ0063
PostPosted: Fri Dec 10, 2010 5:09 pm Up
Not on mine it doesn't! It's blank! Confused
JJ0063
PostPosted: Fri Dec 10, 2010 5:12 pm Up
Don't suppose you know which fuse it is?
I will have to look into that, I also considered trying putting a straight live from the battery to the horn.. then pressing the horn to see if its earthing that way? in theory if its working that way I know it's a definate live problem?
bradshaw1759
best going through all the fuses one by one i was the same only took 10min most of the fuses dont have to be taken out to see if ones blown defo sounds like a fuse to me
Team: Smashed Up Firedance
JJ0063
PostPosted: Fri Dec 10, 2010 5:14 pm Up
Have checked them all mate! layed there for 10 mins today with an inspection lamp looking at them all! lol. thats under dash and engine bay
cheers
PostPosted: Fri Dec 10, 2010 5:22 pm Up
The only fuse is in the engine fuse box, fuse 5.
Is there a horn relay fitted in the engine fuse box?
Is there power going to the switch? If so, press the horn, and see if there's power coming from the switch.
PostPosted: Fri Dec 10, 2010 6:00 pm Up
Rotary switch could be on its way out.
Rotary switch supplies the horn & drivers airbag wiring.
I do know of 1 non plexed 206 that fired the drivers airbag when the horn was pushed due to a worn out rotary switch unit Laughing
JJ0063
PostPosted: Fri Dec 10, 2010 7:12 pm Up
Cheers for the confidence boost! lol
