Posted: Thu Dec 09, 2010 6:41 am |
![](images/spacer.gif) |
Posted: Fri Dec 10, 2010 3:20 am |
tomd0801754................ no idea, But not sure how i would know or check????????????????
Rob2859........................ Ill try and have a look very soon.
Is there a way to look up engine numbers online???
| why wont you work??????????????????? ARGH F**k it!!!!! | |
Posted: Fri Dec 10, 2010 3:24 am |
wikipedia has the engine numbers for peugeot, citreon etc....
Posted: Fri Dec 10, 2010 4:04 am |
rearly???? do i just wack my number in the search?
Posted: Fri Dec 10, 2010 4:15 am |
Posted: Fri Dec 10, 2010 1:04 pm |
The engine will be a TU3JP or a TU3A
The engine number is on the left hand side of the cylinder block. The first three numbers will be the engine code, and it should be the same as the 6th, 7th and 8th letters of your VIN number.
Posted: Fri Dec 10, 2010 1:24 pm |
just because it was originally a 1.4 someone could of put a 1.6 tu lump in check the engine number located where lee says ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Dec 13, 2010 7:12 am |
Having problems seeing where i need to look, The isnt much room to look around these TU engines in a 206..... My old XU lump in the 205 had loads of room to see things.
Any pics to show me the right way would be appreciated?
