Online Now [73]:
Visitors: 72
Today: 72238
Total: 105514224
Forums › The Car › 206 Talk › GTi 180 Gearing
GTi 180 Gearing
L18LTM
PostPosted: Thu Dec 09, 2010 11:58 am Up
how easy would it be to change the gearing on the 180, for quicker 0-60 times ? doesn't matter if top end is reduced as we very rarely use it anyway?
PostPosted: Thu Dec 09, 2010 12:14 pm Up
you can change the final drive ratio or put in a new close-ratio gearbox. but i doubt any of these would reduce 0-60 times
st3v3n
very easy tbh.
Here's a list of gear ratios found in BE boxes
www.taylor-eng.com/gea...earing.htm
And here's how to strip down the box
www.eastment.net/BE3%2...0Strip.htm
ICE goes in drinks. NOT in cars.
st3v3n
PostPosted: Thu Dec 09, 2010 12:19 pm Up
Also, have a read of this
www.106rallyeforum.com...p?p=734541
L18LTM
PostPosted: Thu Dec 09, 2010 12:22 pm Up
thanks mate, how much would it cost for a garage ( specialist ) to do it ?
Dream As If You'll Live Forever, Live As If You'll Die Today Smile
PostPosted: Thu Dec 09, 2010 12:59 pm Up
If you want brand new parts they are pretty expensive. I think the shaft and crown wheel are about £500+.
