Online Now [734]:
Visitors: 733
Today: 143825
Total: 145449500
Forums › The Car › 206 Problems › Alarm Prob - help needed
cookiemonster
PostPosted: Sun Dec 12, 2010 5:32 am Up
Had my car off the road with battery disconnected for 5 weeks, just got the car back yesterday battery reconnected car started straight away but my alarm does not seem to be functioning as it should.
when I lock the door with the key and then press the small top button on fob to alarm the car it makes a BIP noise for about half a second the car is not alarming as the light on the dash is not lit -
can the alarm be re-set in any way please ?
any advise welcome
Used to be in WRX
PostPosted: Sun Dec 12, 2010 6:29 am Up
The BIP noise is telling you that a door / boot / bonnet isnt shut correctly.
The alarm wont arm in that state.
cookiemonster
PostPosted: Sun Dec 12, 2010 6:48 am Up
I cant even set the "panic" alarm off - I can lock the doors and press the small button to alarm which now makes no audible noise and the light on the dash is now flashing to say it is alarmed but unsure how to actually check it !!
Used to be in WRX
PostPosted: Sun Dec 12, 2010 6:49 am Up
What panic alarm? ? ?
cookiemonster
PostPosted: Sun Dec 12, 2010 6:56 am Up
If i was to hold down the small button did it not set the alarm off ?
Used to be in WRX
PostPosted: Sun Dec 12, 2010 6:58 am Up
Not that I know of Laughing
cookiemonster
PostPosted: Sun Dec 12, 2010 7:02 am Up
Sad may have confused this car with the scooby then
Used to be in WRX
PostPosted: Sun Dec 12, 2010 7:03 am Up
Just open & close all the doors, boot, bonnet & try the alarm again.
cookiemonster
PostPosted: Sun Dec 12, 2010 7:05 am Up
cheers Smile
Used to be in WRX
PostPosted: Sun Dec 12, 2010 7:52 am Up
Has yours got the ultrasonic sensors in the A pillars?
If so, put the window down, lock and alarm, than pass your hand infront of the sensor. If it goes off, its fine. If not, then its not fine Wink
cookiemonster
PostPosted: Sun Dec 12, 2010 8:41 am Up
yes tried that tom and even sat in the car alarmed it and jumped about in it like a fool and nothing Sad
Used to be in WRX
PostPosted: Sun Dec 12, 2010 8:47 am Up
Did you check if the doors/boot are shut properly?
cookiemonster
PostPosted: Sun Dec 12, 2010 8:54 am Up
yes ive opened everything n shut everything properly
Used to be in WRX
PostPosted: Sun Dec 12, 2010 9:21 am Up
You tried spraying the bonnet sensor with some WD40?
Its the small black switch attached to the catch.
Check it also hasnt fallen off Laughing
PostPosted: Sun Dec 12, 2010 9:49 am Up
Are all the doors actually locking when you lock the car?
I've got a dicky drivers lock which doesn't always lock and that causes my alarm to not activate.
