Latest: Stu-mill
Overall: 17131
Online Now [47]:
Visitors: 46
Today: 16989
Total: 104904585
Forums › The Car › 206 Problems › grinding noise
grinding noise
harvey
PostPosted: Sun Dec 12, 2010 11:54 am Up
hi i own a 206 1.9d there's a grinding noise coming from the passenger side and the steering slightly shakes iv had the tracking done and the steering still shakes a litlle but the noise has still not gone and has got even worse now i thought it was the pads grinding so i jacked it up took of the passenger side wheel had a look and the brake pads seem to be fine
i spinned around the wheel disc and i could hear a grinding noise like its the driveshaft or something so i stuck the wheel back on and shaked it and the wheel was shaking even the nuts were tighed on so cud any one out there shed some light on this what it could be thanks
harv
troy
PostPosted: Sun Dec 12, 2010 12:08 pm Up
you need to check where the play is, it will either be the track rod end(side of the hub) drumsticks in the rack , bottom ball joint(underneath the hub) or the wheel bearing. get someone else to shake the wheel and try and see/feel where the play is coming from.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
panason1c
PostPosted: Sun Dec 12, 2010 1:05 pm Up
Sounds for sure like the wheel bearing failed, new one is about £30 plus labour (approx 2 hours)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
harvey
PostPosted: Mon Dec 13, 2010 11:21 am Up
hi took it to a mechanic today and he told me it was the wheel bearing does any body know how to change the whee bearing
thanks.
harv
harvey
PostPosted: Wed Dec 15, 2010 3:41 am Up
harv
Big_Rich180
PostPosted: Wed Dec 15, 2010 3:43 am Up
thanks.
Yeah, take it to a garage to be done, I think (could be wrong) they need to be pressed on.
gladiator22
PostPosted: Mon Jan 10, 2011 5:48 pm Up
onHi, yeh the wheel bearing is a press fit in the hub carrier..you'll need a garage to do it ...it's not dificult but you do need a press and some basic Knowledge, good luck
Time served Technician(X peugeot Master Tech)
