Posted: Mon Dec 13, 2010 6:02 pm |
Was coming on for the first week i had the car?
No problems in starting, and i always give it a min or two before i crank it, is it just the dash bulb maybe?-common fault?? Just wanna check before i pull the odometer cluster out.
| | ![](images/spacer.gif) |
Posted: Tue Dec 14, 2010 2:03 am |
The light only comes on when the outside temp is 3 degrees or below.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Tue Dec 14, 2010 2:25 am |
Also if it s warm enough it just flashes on then off, doesn't stay there for very long ;).
Does it start first time all the time?
Posted: Tue Dec 14, 2010 2:48 am |
tomd0801754 wrote: |
Also if it s warm enough it just flashes on then off, doesn't stay there for very long |
Not on mine it doesnt, the only time my g/plug light shows itself is when the outside temp is below 3 degrees, otherwise it stays totally off
BMW K1200RS | |
Posted: Tue Dec 14, 2010 10:02 am |
peterhdi wrote: |
No problems in starting, and i always give it a min or two before i crank it, is it just the dash bulb maybe?-common fault?? Just wanna check before i pull the odometer cluster out. |
Its not cold enough this week for glowplugs to be needed on a HDI ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Tue Dec 14, 2010 2:03 pm |
[/quote]Not on mine it doesnt, the only time my g/plug light shows itself is when the outside temp is below 3 degrees, otherwise it stays totally off[/quote]
Exactly the same on mine and that's exactly how it should operate ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Tue Dec 14, 2010 2:09 pm |
We are still in sub temps up here Hence my point.
