Online Now [1302]:
Visitors: 1301
Today: 105610
Total: 128077083
Forums › The Car › 206 Problems › 1.4 hdi glow plug light?
peterhdi
PostPosted: Mon Dec 13, 2010 7:02 pm Up
Was coming on for the first week i had the car?
No problems in starting, and i always give it a min or two before i crank it, is it just the dash bulb maybe?-common fault?? Just wanna check before i pull the odometer cluster out.
panason1c
PostPosted: Tue Dec 14, 2010 3:03 am Up
The light only comes on when the outside temp is 3 degrees or below.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Tue Dec 14, 2010 3:25 am Up
Also if it s warm enough it just flashes on then off, doesn't stay there for very long ;).
Does it start first time all the time?
panason1c
PostPosted: Tue Dec 14, 2010 3:48 am Up
Not on mine it doesnt, the only time my g/plug light shows itself is when the outside temp is below 3 degrees, otherwise it stays totally off
BMW K1200RS
PostPosted: Tue Dec 14, 2010 11:02 am Up
Its not cold enough this week for glowplugs to be needed on a HDI Wink
continentalgt
PostPosted: Tue Dec 14, 2010 3:03 pm Up
[/quote]Not on mine it doesnt, the only time my g/plug light shows itself is when the outside temp is below 3 degrees, otherwise it stays totally off[/quote]
Exactly the same on mine and that's exactly how it should operate Smile
PostPosted: Tue Dec 14, 2010 3:09 pm Up
We are still in sub temps up here Wink Hence my point.
