Online Now [69]:
Visitors: 68
Today: 70696
Total: 139001075
Forums › The Car › 206 Problems › failed mot
failed mot
CHEQNIK
PostPosted: Fri Dec 10, 2010 3:56 pm Up
hi ecu fixed but failed because radiator fan not working cant test emision any idea please car still in garage trying fix the problem.also air con fan is not working please help.
CHEQNIK
PostPosted: Mon Dec 13, 2010 12:02 pm Up
mot should have tomorow problem was the fan relay was melted so if someones fan on radiator not workin check relays.
PostPosted: Mon Dec 13, 2010 1:14 pm Up
My radiator fan isn't even wired up and it passed.... I don't understand why it would fail otherwise.
kieron
PostPosted: Mon Dec 13, 2010 1:20 pm Up
they cannot fail it on a fan not working its not in the test
Account suspended
panason1c
PostPosted: Mon Dec 13, 2010 2:44 pm Up
As above, rad fan has nothing to do with an mot test. The only concern of the tester is that the engine is at full working temp when the emissions are tested.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
CHEQNIK
PostPosted: Tue Dec 14, 2010 8:26 pm Up
yes thats what he said because temp the mot fail
giveitsomebar
PostPosted: Tue Dec 14, 2010 9:08 pm Up
that makes no sence "because temp mot fail" if you want help you are going to have to write in proper english and explain a bit more. i think what the others are trying to say is that the engine needs to be upto standard heat levels to test emmisions, the fan doesnt stop the engine getting cold so it will still be able to get upto the right temp even with the fan not working, sounds like its sorted now anyway so good luck
CHEQNIK
PostPosted: Thu Dec 16, 2010 9:00 am Up
mot done today tomorow tax
