Posted: Thu Dec 16, 2010 12:26 pm |
about 3 days ago i had a abs fault on my dash come up couple seconds later i had ESP/ASR fault so said to myself ill get that sorted out asap the next day its fine for a few hours then all of a sudden it will come back
its been on and off now for a few days just wanted to know is the asr/esp related to the abs fault or could i have 2 faults?
as its working somtimes and then it is not could the sensors on the hubs just be clogged up ?
any info would be great
cheers kieron
Posted: Thu Dec 16, 2010 12:31 pm |
mine does this with just the abs light as i only have abs, my n/s front abs ring is cracked so it randomly birings up a fault every once in a wile. if you can afford a diagnostic check then i would jack the car up and check both front abs rings for cracks as they are very common to break.
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Thu Dec 16, 2010 12:34 pm |
i can get it diagnostic checked yes
would the cracks stand out i had a quick look at the rings the other day and to be fair the all seems fine
the light will sometimes be on from start up and other times it will be fine
Posted: Thu Dec 16, 2010 12:38 pm |
ye, it would be a full crack all the way through the abs ring, if theyre not broken then your only bet is to get it plug into a diagnosis machine.
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Thu Dec 16, 2010 12:44 pm |
Try giving the rings and sensors a good clean-up first.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Fri Dec 17, 2010 4:55 pm |
| kieron206gti wrote: |
cheers kieron |
Kieron why you all ways post on here before asking me to have a look at it lol come down monday and i put on diag and see whats going on.
kyle
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Fri Dec 17, 2010 4:58 pm |
because im not a retard only joking
Posted: Fri Dec 17, 2010 5:08 pm |
because im not a retard only joking |
haha d.i.c.k
you going to bring it done to me on monday dude.
180 Doctor
Posted: Fri Dec 17, 2010 5:12 pm |
| gti180boy wrote: |
haha d.i.c.k
you going to bring it done to me on monday dude. |
yes can do if you dont mind..............
Posted: Fri Dec 17, 2010 5:18 pm |
| gti180boy wrote: |
haha d.i.c.k
yes can do if you dont mind.............. |
No dont mind whats bro's for
180 Doctor
