Online Now [298]:
Visitors: 297
Today: 70555
Total: 128288135
Forums › The Car › 206 Problems › I Think My Power Steering Is Gone
JDave
PostPosted: Thu Dec 16, 2010 1:51 pm Up
Hi,
Well yesterday night as arrived home, I approached the house and turned the radio off, then when I turned in my drive I heard this horrid noise. Geniunely like a T-Rex roaring but far away (its hard to describe). Well since then turning the wheel past 45 degrees either way is difficult and this noise is still here.
Am I right? Is it expensive to fix?
Thanks,
JD
Click To View My Project
apjs87
PostPosted: Thu Dec 16, 2010 1:58 pm Up
Aux belt slipping? Topped up steering fluid?
No longer a 206 owner
Astra H sxi. 1.7Cdti
PostPosted: Thu Dec 16, 2010 3:26 pm Up
if powwer steering is gone, you will find it hard to turn the steering wheel at the whole range, not only pass 45"
PostPosted: Thu Dec 16, 2010 3:30 pm Up
You know when the PAS has gone, you need both hand to steer all the time, and it fells like you are steering with 2 flat tyres.
JDave
PostPosted: Thu Dec 16, 2010 9:46 pm Up
Well I wound't know as I haven't knowgly driven without power steering. Any ideas?
panason1c
PostPosted: Fri Dec 17, 2010 2:16 am Up
Low power steering fluid level (due to a leak) will cause your symptoms, the noise you hear is caused by the pump 'scavenging' for fluid. Check the level.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
JDave
PostPosted: Fri Dec 17, 2010 12:37 pm Up
That is exactly what was wrong. Took it to the garage, they filled it up with fluid and are going to annalyse how long it takes to run out.
Thank you.
Thread closed.
actionman
PostPosted: Sat Dec 25, 2010 6:50 am Up
I hardly drive our 206 as the Mrs uses it for work, i moved it on teh drive the other day & noticed an awful racket coming from the front!! Luckily i've had this before with 1 of my old cars so knew it was low PAS fluid!! Topped it up & the noise went straight away!! I've noticed a small amount of PAS fluid on the bottom drivers side of the engine, need to get it in my garage over my pit so I can have a proper look!!
I also think there's a slight diesel leak as well at the same side of the engine!! There was a very very small patch on the drive the other day, after a quick dip finger & taste check i'm pretty sure it's diesel!! Rolling Eyes
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
Davo_Pug
PostPosted: Wed Dec 29, 2010 5:53 am Up
Actionman...I had the same problems before...well still hae the occasional spot of deisel...but the powersteering fluid problem..I would check asap...because if your PAS resrvoir is leaking because of the position of the alternator directly beneath you dont want it leaking onto it as it will eventually bust your alternator....as I found out coming down the mountain road with no power or PAS ....I cacked myself!!!!!!
Davo_
