Posted: Fri Dec 24, 2010 1:04 pm |
The other week I found a whole bottle of wilko screenwash which someone had kindly left me in the carpark. I therefor claimed it and brimmed my bottle.
I went to my car earlier to find blue icicles coming from my bumper to the floor. They seem mostly to be coming from the flat section of the arch lining.
Is it likely that the bottle has split or a pipe has come off?
Can I avoid removing the lining as its a ball ache?
Posted: Fri Dec 24, 2010 1:27 pm |
mine done this, well similar, where the neck and the bottle join isnt watertight on mine! took me a few mins to work out why it was taking so much water to fill up
Posted: Fri Dec 24, 2010 1:41 pm |
just to fill it up to the neck,because when it gets to the neck it will spell it all on the floor,mine do the same
Posted: Fri Dec 24, 2010 1:51 pm |
I brimed it to the neck and didn't use it and when i lookedthe neck was empty. no sign of leakinging from there. Just down off the bumper. it looks like the car is melting.
Posted: Fri Dec 24, 2010 3:05 pm |
| Antknee wrote: |
mine done this, well similar, where the neck and the bottle join isnt watertight on mine! took me a few mins to work out why it was taking so much water to fill up  |
Exactly what mine does. I've never fixed it just take more trips to the tap.
Posted: Fri Dec 24, 2010 3:26 pm |
has the O ring halfway down snapped? causing it to leak at the joint (about 8 inches down from the top).
i recently had to replace it on the 206 (again).
| Former owner of a 1.4 HDi for six years | |
Posted: Fri Dec 24, 2010 6:11 pm |
| skard wrote: |
i recently had to replace it on the 206 (again). |
do you mean where the pipe removes so you can access the headlight?
Posted: Sat Dec 25, 2010 2:41 pm |
yes
Posted: Wed Dec 29, 2010 5:46 am |
It has a separate neck that attaches to the main reervoir of the screen wash as Antknee said it isnt water tight and sometimes needs a wiggle to realign it better....I once thought my car was melting too!!haha
Posted: Wed Dec 29, 2010 7:31 am |
Thats carma for you, you shouldn't be stealing
