Online Now [187]:
Visitors: 186
Today: 119425
Total: 128336874
Forums › The Car › 206 Problems › Crazy knocking on the rear axle.
sicskate
PostPosted: Thu Dec 16, 2010 2:30 pm Up
Trade Rating: +13
3 months ago I fitted a 180 axle as my 138 one had given up the ghost.
A month later I lowered the rear.
A week or so later the car developed an odd knocking.
Driving straight there in no noise, even on bumpy roads.
But turning left will knock, if turning left again there will be NOTHING...
As soon as I turn right, it will knock again.
Strange huh??
Sounds like something is knocking in and out (a guess!) as it won't knock on more than one turn left untill I turn right, and the same viceversa.
Any suggestions?
Many thanks
Ben
307 1.4hdi Smile
PostPosted: Thu Dec 16, 2010 2:31 pm Up
Rear axle is FUBAR.
In other words, the bushes are worn.
PostPosted: Thu Dec 16, 2010 2:32 pm Up
lso, jack the rear, grab the wheel at ten to 3. Shake, does the wheel move?
sicskate
PostPosted: Thu Dec 16, 2010 2:38 pm Up
Trade Rating: +13
Hmm... I hope not, the new axle had only done 33k!
307 1.4hdi Smile
A18NHH
PostPosted: Thu Dec 16, 2010 3:16 pm Up
lowering it wont help i believe...
Wahoo!
sicskate
PostPosted: Thu Dec 16, 2010 3:30 pm Up
Trade Rating: +13
I only went -30mm. Surly this couldn't cause too much damage?
307 1.4hdi Smile
PostPosted: Thu Dec 16, 2010 4:02 pm Up
when you fit the 180axle, have you renew the bearing before you put the axle on?
sure you havnt left anything loose just double check shock bolts, arb bolts etc
i know it sounds silly but before you assume the worst it pays to check the simple things Smile
sicskate
PostPosted: Thu Dec 16, 2010 4:29 pm Up
Trade Rating: +13
Well, saying that, I did swap them from my old axle as otherwise I'd have an abs fault.
I'll strip it down and investigate asap.
307 1.4hdi Smile
