Posted: Thu Dec 16, 2010 2:49 pm |
hi guys,
ive had a small oil leak coming from somewhere for a while but recently its got really bad! last week i lost nearly a litre! its coming from under the engine on the drivers side and its flicking up off a belt onto the underside of my bonet and its getting onto my drivers side front wheel and spraying down the side of my car! i really need to get it sorted but cant actually see where its coming from. im assuming its a gasket or seal gone of some sort but can anyone tell me what it may be likely to be
any help or advice would be greatly appreciated
Posted: Thu Dec 16, 2010 2:50 pm |
Probaly your crankshaft seal, basically STOP USING YOUR CAR
It has most likely leaked on the cambelt so dont even start the car
| Team Impossible Possible
Posted: Thu Dec 16, 2010 2:57 pm |
addaz wrote: |
It has most likely leaked on the cambelt so dont even start the car |
oil on the belt-->belt slip when engine start-->bang!
Posted: Thu Dec 16, 2010 2:58 pm |
someone else told me it might be that :S bit late for not starting my car though.... b***cks what can happen?
Posted: Thu Dec 16, 2010 2:59 pm |
If it slips wave bye bye to your engine!
Posted: Thu Dec 16, 2010 3:01 pm |
Look at the engine and take note, because that might be the last time you see it in one piece
Posted: Thu Dec 16, 2010 3:03 pm |
is crankshaft seal a big job to do ?
Posted: Thu Dec 16, 2010 3:09 pm |
depends on which side lol i had the one behind the flywheel leak did it myself cost £10 however gearbox clutch flywheel needs to come off lol
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
