Latest: tbafonso
Overall: 17130
Online Now [26]:
Visitors: 25
Today: 8099
Total: 104517764
Forums › The Car › 206 Problems › temperature sender sensor
Go to page Previous  1, 2
johnk
PostPosted: Thu Dec 30, 2010 11:24 am Up
Another quick question, how does the fan know when to come on? is it triggered by the temp gauge? if so does that mean my car will overheat as my gauge doesnt work and just sits at zero.
Old info post count 1500
mjsroofing
PostPosted: Thu Dec 30, 2010 11:26 am Up
no it a it's own sensor on rad
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
johnk
PostPosted: Thu Dec 30, 2010 11:28 am Up
Cool cheers for that just wanted to make sure i wasnt going to fry the thing Laughing
mjsroofing
PostPosted: Thu Dec 30, 2010 11:30 am Up
test it, start engine, wait for it to reach running temp and see if fan kicks in
Mark
PostPosted: Thu Dec 30, 2010 1:32 pm Up
There is only one coolant sensor on the GTi. The ECU switches on the fan when the sensor tells the ECU the coolant is at a particular temperature. The ECU uses the same infomation to work the guage.
mjsroofing
PostPosted: Fri Dec 31, 2010 2:38 am Up
my mistake, sorry.
Mark
Page 2 of 2
