Latest: Worthy967
Overall: 17143
Online Now [62]:
Visitors: 61
Today: 19651
Total: 114920042
Forums › The Car › 206 Talk › Brake fluid
Brake fluid
LiamGTi180
PostPosted: Sat Nov 24, 2012 9:51 am Up
I've just replaced brake discs and pads all round on the 180. It has made a great difference (the old ones were f****d) but they still feel a bit spongey. So I am guessing the brake fluid needs changing. I have heard that bleeding the brakes is a ball ache and you need PP to open a valve Confused Anyone know how much Peugeot charge (roughly) to bleed and replace brake fluid?
PostPosted: Sat Nov 24, 2012 10:30 am Up
Too much! Might be better to try an independent auto electrician who has PP. They can bleed brakes.
PostPosted: Sat Nov 24, 2012 10:37 am Up
98.66 vat included
LiamGTi180
PostPosted: Sat Nov 24, 2012 11:54 am Up
Seabook wrote:
98.66 vat included
Ouch that is expensive. Might be cheaper to crash into the back of someone then. Only £50 excess Wink
PostPosted: Sat Nov 24, 2012 12:49 pm Up
They will feel odd for the first few days. Have you allowed time for the new pads to bed in properly by braking gently?
PostPosted: Sat Nov 24, 2012 12:52 pm Up
Did you clean the storage oil of the discs after fitting them on the hubs & before you fitted the pads?
PostPosted: Sat Nov 24, 2012 5:47 pm Up
Rolling On The Floor Laughing
Use PP to bleed it through the ABS? b******s to that, we only do that if we replace the unit to remove the first air bubbles
Otherwise just keep the level up and 12 pumps on each one working from furtherest away from cylinder to closest
Side note, brake line twisted by any chance?
