Online Now [565]:
Visitors: 564
Today: 9981
Total: 105736635
Forums › The Car › 206 Problems › Overheating
Overheating
Davrob7
PostPosted: Tue Dec 28, 2010 2:26 pm Up
My wife has a 2001 1.4 LX which she's had from new. Just spent a fortune on it, Airbags and Airbags ECU, wishbones, drop arms, discs etc. She also had an overheating problem which we thought had been solved with new resistors. It was the needle zooming to the red and the stop warning lamp coming on which quite a few others have noted on this site. The fan does not come on. New resistors got it working for a while but its gone again. She only uses it as a shopping trolley so we are reluctant to spend much more money on it (the other jobs cost £800) so I am thinking of wiring the fan so it is on all the time. Am I right in thinking I have to join the two wires that presently go into the sensor on the bottom of the radiator? Before the present problem the fan used to work all the time anyway for over a year with no problems....but does anybody know if this is a good idea or would having the fan on all the time cause other problems?
Bamboozled
PostPosted: Tue Dec 28, 2010 2:31 pm Up
There should only be one resistor for the cooling fan circuit.
Are the relays behind the grill ok / not corroded in to a green powdery mess?
Davrob7
PostPosted: Tue Dec 28, 2010 2:51 pm Up
Sorry it was relays I meant. Both were changed which seemed to solve the problem for a few weeks. The wiring seemed ok at the time I changed them.
Bamboozled
mjsroofing
PostPosted: Tue Dec 28, 2010 4:23 pm Up
maybe the fan is on its way out, try testing fan first mate.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Davrob7
PostPosted: Wed Dec 29, 2010 4:41 am Up
The fan comes on with the A/C so the motor is ok and power is getting to it. In fact if you drive around with the A/C on the problem doesn't arise.
Bamboozled
PostPosted: Wed Dec 29, 2010 7:40 am Up
Change the coolant temp sensor.
