Posted: Fri Dec 24, 2010 2:00 pm |
I just opened car up in second into third, then all lights went out, The ignition had turned off. I turned it back on and car had no power, foot to the floor. When in first of second it takes a while for the power to build. Its to dark and cold just now to have a look. Any ideas. I need my car for tomorrrow.
| Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. | |
Posted: Fri Dec 24, 2010 3:46 pm |
sounds like its gone into limp mode check the battery terminals are tight
im not sure how to get it out of limp mode someone else might be able to help you there
Posted: Fri Dec 24, 2010 4:55 pm |
giveitsomebar wrote: |
im not sure how to get it out of limp mode someone else might be able to help you there |
My Focus ST had limp mode and it dropped the boost off, No engine management light on either. Diagnostics machine no doubt.Thanks mate hope so.
Posted: Fri Dec 24, 2010 5:02 pm |
EML light should come on with limp mode. Did with mine. turn it off and back on again that should get you out of limp mode
Posted: Sat Dec 25, 2010 6:27 am |
Been out this morning and had a wee run around streets and car seems fine, I hope. Would like to know what caused this.
Posted: Sat Dec 25, 2010 6:51 am |
Trade Rating: +37
It went into limp mode then, should've stored a fault code for you to check on diag at a later date. EML does not always come on due to limp mode. Mine did it once before and was fine the next time I fired her up.
